[postgis-tickets] [PostGIS] #2784: configure --with-scfgal=/usr/local/bin won't fail
PostGIS trac at osgeo.org
Thu Jun 26 00:58:22 PDT 2014
 Reporter:  vmo     |       Owner:  robe
     Type:  patch   |      Status:  new
 Priority:  medium  |   Milestone:
Component:  sfcgal  |     Version:  2.1.x
 Keywords:          |
Comment(by strk):
 I saw the problem is use of "test -x" which tests if a file is
 "executable".
 Directories are "executable" if they can be browsed, so the test should be
 changed to test for the file to be "a file" _and_ be "executable".
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2784#comment:3>
