[postgis-tickets] [PostGIS] #2787: build issues with git/svn source codes.
PostGIS trac at osgeo.org
Thu Jun 26 08:12:54 PDT 2014
 Reporter:  mohitkharb     |       Owner:  robe
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.1.4
Component:  documentation  |     Version:  2.1.x
 Keywords:                 |
Comment(by pramsey):
 bison/flex are not requirements because their outputs are checked into the
 repository. The only time they should get called is if for some reason you
 update the lexer or parser (which you have no reason to do). And we do
 require the gnu tools (bison/flex) not the older (yacc/lex) ones.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2787#comment:2>
