[postgis-tickets] [PostGIS] #2786: st_buildArea returns null geom
PostGIS trac at osgeo.org
Thu Jun 26 09:32:43 PDT 2014
 Reporter:  mjurce   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by robe):
 mjurce,
 That would just cover under the blankets any issues.  That's more like a
 workaround or something that should be done by the user.
 For example with ST_SimplifyPreserveTopology the tolerance you would want
 depends on spatial ref so we can't hard code something there. Nor do I
 think we should cause you might not want any simplification.
 As far as ST_MakeValid that does have the issue of giving you something
 you don't want.  So I think those types of solutions should be left up to
 the discretion of the user.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2786#comment:3>
