[postgis-tickets] [PostGIS] #2788: Warning on PG_RETURN_HEAPTUPLEHEADER building against PgSQL 9.4
PostGIS trac at osgeo.org
Fri Jun 27 03:13:05 PDT 2014
 Reporter:  pramsey  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.4
Component:  postgis  |     Version:  2.1.x
 Keywords:  9.4      |
Comment(by robe):
 ah I see it.  Just to add this one is in building 2.2
 lwgeom_geos.c: In function 'isvaliddetail':
 lwgeom_geos.c:1901:2: warning: passing argument 1 of
 'HeapTupleHeaderGetDatum' makes pointer from integer without a cast
 [enabled by default]
   PG_RETURN_HEAPTUPLEHEADER(result);
 In file included from lwgeom_geos.c:24:0:
 e:/jenkins/postgresql/rel/pg9.4w32gcc481/include/server/funcapi.h:232:14:
 note: expected 'HeapTupleHeader' but argument is of type 'Datum'
  extern Datum HeapTupleHeaderGetDatum(HeapTupleHeader tuple);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2788#comment:2>
