[postgis-tickets] [PostGIS] #2789: regression test in raster not compatible with pgsql 9.0
PostGIS trac at osgeo.org
Fri Jun 27 11:10:41 PDT 2014
 Reporter:  pramsey  |       Owner:  dustymugs
     Type:  defect   |      Status:  new
 Priority:  low      |   Milestone:  PostGIS 2.1.4
Component:  raster   |     Version:  2.1.x
 Keywords:           |
 We promise compatibility back to 9.0 with 2.1, but you cannot regress it,
 because a test calls a function that does not exist, right():
 --- rt_utility_expected 2014-06-24 13:54:32.000000000 -0700
 +++ /tmp/pgis_reg/test_41_out   2014-06-27 11:08:17.000000000 -0700
 @@ -37,5 +37,4 @@
      band 3 of pixtype 16BSI is in-db with no NODATA value
  Skewed raster of 10x10 pixels has 1 band and extent of BOX(0 -10,10
 0.0001)
      band 1 of pixtype 8BUI is in-db with NODATA value of 0
 -NOTICE:  Could not find raster band of index 1 when getting band path.
 Returning NULL
 -bandpath1|
 +ERROR:  function right(text, integer) does not exist at character 99
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2789>
