[postgis-tickets] [PostGIS] #2790: SET_VARSIZE redefined
PostGIS trac at osgeo.org
Fri Jun 27 14:50:36 PDT 2014
 Reporter:  robe    |       Owner:  colivier
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.2.0
Component:  sfcgal  |     Version:  trunk
 Keywords:          |
 I'm seeing this warning in PostgreSQL 9.4 when building sfcgal not sure if
 its serious or not.  Doesn't seem to affect anything.
 Might be in other versions but not currently building other versions yet
 with sfcgal support.
 In file included from ../libpgcommon/lwgeom_pg.h:23:0,
                  from lwgeom_sfcgal.c:19:
 ../libpgcommon/pgsql_compat.h:16:0: warning: "SET_VARSIZE" redefined
 [enabled by default]
  #define SET_VARSIZE(var, size)   VARATT_SIZEP(var) = size
 In file included from lwgeom_sfcgal.c:15:0:
 e:/jenkins/postgresql/rel/pg9.4w64gcc48/include/server/postgres.h:299:0:
 note: this is the location of the previous definition
  #define SET_VARSIZE(PTR, len)    SET_VARSIZE_4B(PTR, len)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2790>
