[postgis-tickets] [PostGIS] #2791: raster regress failure with GDAL 1.11.0 on mingw64
PostGIS trac at osgeo.org
Sat Jun 28 11:56:49 PDT 2014
 Reporter:  robe     |       Owner:  dustymugs
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  raster   |     Version:  trunk
 Keywords:  mingw64  |
 I'm getting this failure on raster -- only one failing.
 Fails on  winnie. Goind to check my local dev to see if it fails.  As I
 recall it does.
 I think I have my environment variable right
 GDAL_DATA=path/to/gdal/share
 wher path/to is my gdal-1.11.0 installed location and I see the file in
 that folder.
 Suite: gdal
   Test: test_gdal_configured ...ERROR 4: Unable to open EPSG support file
 gcs.csv.
 Try setting the GDAL_DATA environment variable to point to the
 directory containing EPSG csv files.
 FAILED
     1. cu_gdal.c:28  - rt_util_gdal_configured()
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2791>
