[postgis-tickets] [PostGIS] #2794: winnie regress failures for sfcgal - 2 errors
PostGIS trac at osgeo.org
Sat Jun 28 23:20:00 PDT 2014
 Reporter:  robe    |       Owner:  colivier
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.2.0
Component:  sfcgal  |     Version:  trunk
 Keywords:          |
 Turned on the switch to have winnie start regress testing sfcgal and still
 getting errors.
 PostgreSQL 9.3.4, compiled by Visual C++ build 1600, 64-bit
   Postgis 2.2.0dev
  - r12700
  - 2014-06-29 05:58:40
   scripts 2.2.0dev r12700
   GEOS: 3.5.0dev-CAPI-1.9.0 r3989
   PROJ: Rel. 4.8.0, 6 March 2012
 Running tests
  loader/Point .............. ok
  loader/PointM .............. ok
  loader/PointZ .............. ok
  loader/MultiPoint .............. ok
  loader/MultiPointM .............. ok
  loader/MultiPointZ .............. ok
  loader/Arc .............. ok
  loader/ArcM .............. ok
  loader/ArcZ .............. ok
  loader/Polygon .............. ok
  loader/PolygonM .............. ok
  loader/PolygonZ .............. ok
  loader/TSTPolygon ......... ok
  loader/TSIPolygon ......... ok
  loader/TSTIPolygon ......... ok
  loader/PointWithSchema ..... ok
  loader/NoTransPoint ......... ok
  loader/NotReallyMultiPoint ......... ok
  loader/MultiToSinglePoint ......... ok
  loader/ReprojectPts ........ ok
  loader/ReprojectPtsGeog ........ ok
  loader/Latin1 .... ok
  loader/Latin1-implicit .... ok
  dumper/literalsrid ....... ok
  dumper/realtable ....... ok
  binary .. ok
  regress .. ok
  regress_index .. ok
  regress_index_nulls .. ok
  regress_selectivity .. ok
  lwgeom_regress .. ok
  regress_lrs .. ok
  removepoint .. ok
  setpoint .. ok
  simplify .. ok
  snaptogrid .. ok
  summary .. ok
  affine .. ok
  empty .. ok
  forcecurve .. ok
  measures .. ok
  legacy .. ok
  long_xact .. ok
  ctors .. ok
  sql-mm-serialize .. ok
  sql-mm-circularstring .. ok
  sql-mm-compoundcurve .. ok
  sql-mm-curvepoly .. ok
  sql-mm-general .. ok
  sql-mm-multicurve .. ok
  sql-mm-multisurface .. ok
  polyhedralsurface .. ok
  polygonize .. ok
  postgis_type_name .. ok
  geography .. ok
  out_geometry .. ok
  out_geography .. ok
  in_geohash .. ok
  in_gml .. ok
  in_kml .. ok
  iscollection .. ok
  regress_ogc .. ok
  regress_ogc_cover .. ok
  regress_ogc_prep .. ok
  regress_bdpoly .. ok
  regress_proj .. ok
  regress_management .. ok
  dump .. ok
  dumppoints .. ok
  boundary .. ok
  wmsservers .. ok
  wkt .. ok
  wkb .. ok
  tickets .. ok
  typmod .. ok
  remove_repeated_points .. ok
  split .. ok
  relate .. ok
  bestsrid .. ok
  concave_hull .. ok
  twkb .. ok
  hausdorff .. ok
  regress_buffer_params .. ok
  offsetcurve .. ok
  relatematch .. ok
  isvaliddetail .. ok
  sharedpaths .. ok
  snap .. ok
  node .. ok
  unaryunion .. ok
  clean .. ok
  relate_bnr .. ok
  delaunaytriangles .. ok
  in_geojson .. ok
  regress_sfcgal .. failed (diff expected obtained:
 /projects/postgis/tmp/2.2.0dev_pg9.3_geos3.5.0dev_gdal1.10.0w64/test_95_diff)
 --- regress_sfcgal_expected     2014-06-28 18:10:01 -0400
 /projects/postgis/tmp/2.2.0dev_pg9.3_geos3.5.0dev_gdal1.10.0w64/test_95_out
 2014-06-29 02:06:03 -0400
 @@ -1,14 +1,14 @@
 -postgis_sfcgal_version|1
 -ST_Tesselate|GEOMETRYCOLLECTION(POINT(4 4),TIN(((0 1,1 0,1 1,0 1)),((0
 1,0 0,1 0,0 1))))
 -ST_3DArea|1
 -ST_Extrude_point|LINESTRING Z (0 0 0,1 0 0)
 -ST_Extrude_line|POLYHEDRALSURFACE Z (((0 0 0,1 0 0,1 1 0,0 1 0,0 0 0)))
 -ST_Extrude_surface|POLYHEDRALSURFACE Z (((1 1 0,1 0 0,0 1 0,1 1 0)),((0 1
 1,1 0 1,1 1 1,0 1 1)),((1 0 0,0 0 0,0 1 0,1 0 0)),((0 1 1,0 0 1,1 0 1,0 1
 1)),((1 0 0,1 1 0,1 1 1,1 0 1,1 0 0)),((1 1 0,0 1 0,0 1 1,1 1 1,1 1
 0)),((0 1 0,0 0 0,0 0 1,0 1 1,0 1 0)),((0 0 0,1 0 0,1 0 1,0 0 1,0 0 0)))
 -ST_ForceLHR|POLYGON((0 0,1 0,1 1,0 1,0 0))
 -ST_Orientation_1|-1
 -ST_Orientation_2|1
 -ST_MinkowskiSum|MULTIPOLYGON(((0 0,1 0,5 0,5 1,4 1,0 1,0 0)))
 -ST_StraightSkeleton|MULTILINESTRING((0 0,0.5 0.5),(1 0,0.5 0.5),(1 1,0.5
 0.5),(0 1,0.5 0.5))
 +ERROR:  function postgis_sfcgal_version() does not exist at character 56
 +ERROR:  function st_tesselate(unknown) does not exist at character 34
 +ERROR:  function st_3darea(unknown) does not exist at character 21
 +ERROR:  function st_extrude(unknown, integer, integer, integer) does not
 exist at character 38
 exist at character 48
 +ERROR:  function postgis_sfcgal_version() does not exist at character 41
 +ERROR:  function st_forcelhr(unknown) does not exist at character 33
 +ERROR:  function st_forcelhr(unknown) does not exist at character 43
 +ERROR:  function st_orientation(geometry) does not exist at character 28
 +ERROR:  function st_minkowskisum(unknown, unknown) does not exist at
 character 37
 +ERROR:  function st_straightskeleton(unknown) does not exist at character
 41
  intersection_geos|POINT(0 0)
  intersection_sfcgal|POINT(-0 -0)
  ERROR:  Can't find foo geometry backend
  sfcgal/empty .. ok
  sfcgal/geography .. ok
  sfcgal/legacy .. ok
  sfcgal/measures .. ok
  sfcgal/regress_ogc_prep .. ok
  sfcgal/regress_ogc .. ok
  sfcgal/regress .. ok
  sfcgal/tickets .. failed (diff expected obtained:
 /projects/postgis/tmp/2.2.0dev_pg9.3_geos3.5.0dev_gdal1.10.0w64/test_103_diff)
 --- sfcgal/tickets_expected     2014-06-28 18:09:59 -0400
 /projects/postgis/tmp/2.2.0dev_pg9.3_geos3.5.0dev_gdal1.10.0w64/test_103_out
 2014-06-29 02:06:07 -0400
 @@ -95,7 +95,7 @@
  #835.11|MULTILINESTRING EMPTY
  #835.12|MULTIPOLYGON EMPTY
  #650|MULTIPOINT(0 0,1 1,2 2)
 -#667|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(30 40,-50 39.9999999999999,30
 40))
 +ERROR:  function postgis_sfcgal_version() does not exist at character 118
  #677|1121395
  #680|01d107000000000000000024c000000000000049400000000000000040
  #681a|
  sfcgal/concave_hull .. ok
  sfcgal/wmsservers .. ok
  uninstall .  /projects/postgis/branches/2.2/regress/00-regress-
 install/share/contrib/postgis/uninstall_postgis.sql
 . ok (4112
 Run tests: 106
 Failed: 2
 Makefile:210: recipe for target `check' failed
 make[1]: *** [check] Error 2
 make[1]: Leaving directory `/projects/postgis/branches/2.2/regress'
 GNUmakefile:14: recipe for target `check' failed
 make: *** [check] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2794>
