[postgis-tickets] [PostGIS] #2796: sfcgal_comments.sql missing for regress testing install
PostGIS trac at osgeo.org
Sun Jun 29 14:45:39 PDT 2014
 Reporter:  robe    |       Owner:  colivier
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.2.0
Component:  sfcgal  |     Version:  trunk
 Keywords:          |
 Okay winnie is now passing the sfcgal tests but I noticed the
 sfcgal_comments.sql install missing in her output:
 TMPDIR is /projects/postgis/tmp/2.2.0dev_pg9.3_geos3.5.0dev_gdal1.10.0w64
 Creating database 'postgis_reg'
 Loading PostGIS into 'postgis_reg'
   /projects/postgis/branches/2.2/regress/00-regress-
 install/share/contrib/postgis/postgis.sql
 install/share/contrib/postgis/postgis_comments.sql
 Loading SFCGAL into 'postgis_reg'
 install/share/contrib/postgis/sfcgal.sql
 PostgreSQL 9.3.4, compiled by Visual C++ build 1600, 64-bit
   Postgis 2.2.0dev
  - r12703
  - 2014-06-29 21:28:47
   scripts 2.2.0dev r12703
   GEOS: 3.5.0dev-CAPI-1.9.0 r3989
   PROJ: Rel. 4.8.0, 6 March 2012
   SFCGAL: 1.0.4
 The comments seem to be installed fine for create extension.
 We install the comments during regress as well to catch incongruencies
 between the documentation and what is actually implemented.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2796>
