[postgis-tickets] [PostGIS] #2798: raster2pgsql spins CPU on statement timeout
PostGIS trac at osgeo.org
Mon Jun 30 10:56:59 PDT 2014
 Reporter:  strk      |       Owner:  dustymugs
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:
Component:  raster    |     Version:  trunk
 Keywords:            |
 After waiting for an hour that a raster import completed, with CPU coolers
 screaming as hell, I finally went looking in pg_stat_activity and found
 that the transaction was aborted due to a timeout:
 state            | idle in transaction (aborted)
 query            | COPY "timeseq_change00_12" ("rast") FROM stdin;
 This occurrence evidently did not stop raster2pgsql which took away my CPU
 and tried to kill it.
 This is with current PostGIS trunk and GDAL 1.11.0
 The test dataset is "Indonesia time-sequential primary forest extent and
 loss" http://glad.geog.umd.edu/indonesia/data2014/index.html
 The import command:
   raster2pgsql -C -I -s 4326 -Y -t 256x256 \
     timeseq_change00_12.tif timeseq_change00_12
 Some top(1) extracts:
   PID USER      PR  NI  VIRT  RES  SHR S  %CPU %MEM    TIME+  COMMAND
 13229 strk      20   0  222m  47m 2068 R  99.2  1.2  58:00.08 raster2pgsql
 13230 strk      20   0 29160 1192  924 S   0.7  0.0   0:22.77 psql
 13231 strk      20   0  181m  10m 6340 S   0.7  0.3   0:32.82 postgres
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2798>
