[postgis-tickets] [PostGIS] #2791: raster regress failure with GDAL 1.11.0 on mingw64
PostGIS trac at osgeo.org
Mon Jun 30 16:12:46 PDT 2014
  Reporter:  robe       |       Owner:  dustymugs
      Type:  defect     |      Status:  closed
  Priority:  blocker    |   Milestone:  PostGIS 2.2.0
 Component:  buildbots  |     Version:  trunk
Resolution:  fixed      |    Keywords:  mingw64
Changes (by robe):
  * status:  reopened => closed
  * resolution:  => fixed
  * component:  raster => buildbots
Comment:
 Should be fixed at r12711
 I'm running 4 different versions of mingw64 (don't ask) and I have all the
 libraries suffixed to match up with the mingw that generates it.  I missed
 a spot on the GDAL_DATA.
 (also have to fix in my postgresql env variable I think)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2791#comment:3>
