[postgis-tickets] [PostGIS] #2382: Can't upgrade postgis ERROR: attempt to redefine parameter "postgis.backend"
PostGIS trac at osgeo.org
Sat Mar 1 20:36:57 PST 2014
"postgis.backend"
 Reporter:  robe                   |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 Here is where it's set
 http://postgis.net/docs/doxygen/2.2/d9/d85/lwgeom__backend__api_8c_a0bc0c2461640915a80936b0b7cf83b74.html#a0bc0c2461640915a80936b0b7cf83b74
 and gets called in _PG_init.
 I wonder if it only shows up between minor upgrade e.g. 2.1 to 2.2 because
 that is the only time when the 2.1 and 2.2 are simultaneously active (as
 2.2.so/dll is swapping out a possibly live 2.1.so/dll)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2382#comment:13>
