[postgis-tickets] [PostGIS] #2659: extension upgrade from 2.1.2dev to 2.2.0dev fails with st_countagg(raster, integer, boolean, double precision) does not exist
PostGIS trac at osgeo.org
Mon Mar 3 05:47:29 PST 2014
st_countagg(raster,integer,boolean,double precision) does not exist
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 Actually I think I was running the wrong raster_upgrade.sql.  I was using
 a winnie package and must have overlaid it over my existing.  I must have
 something hard-coded in winnie to output the named old file name, so the
 package she has is not packaging raster_upgrade.sql or
 postgis_upgrade.sql.  so it's probably the same issue with the old-
 fashioned upgrade.
 BTW we need to upgrade the docs for 2.2 to reflect this change.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2659#comment:5>
