[postgis-tickets] [PostGIS] #2659: extension upgrade from 2.1.2dev to 2.2.0dev fails with st_countagg(raster, integer, boolean, double precision) does not exist
PostGIS trac at osgeo.org
Mon Mar 3 08:54:02 PST 2014
st_countagg(raster,integer,boolean,double precision) does not exist
 Reporter:  robe                   |       Owner:  dustymugs
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Changes (by dustymugs):
  * owner:  strk => dustymugs
Comment:
 I'll fix the upgrade issue and update the docs. Is the same happening for
 ST_SummaryStatsAgg?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2659#comment:8>
