[postgis-tickets] [PostGIS] #2662: RGeo - PostGis - SRID - Recording
PostGIS trac at osgeo.org
Tue Mar 4 06:22:40 PST 2014
 Reporter:  benebrice  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  high       |   Milestone:  PostGIS 2.1.2
Component:  postgis    |     Version:  2.1.x
 Keywords:             |
 Hello,
 I am currently working with RGeo and PostGIS on a Rails application (Rails
 4.0.2, Ruby 2.1).
 I think I have found a problem coming from the recording of a position.
 You can find [https://github.com/dazuma/rgeo/issues/54 here ] an post at
 the end where I explain all my problems.  At the beginning I thought that
 the problem came from RGeo but now I am not really sure.
 To install PostGIS I used [http://postgresapp.com/ PostgresApp] and the
 following code lines to create the template used for the creation of my
 database with Rails.
 sudo su postgres
 createdb template_postgis
 createlang plpgsql template_postgis
 psql -d template_postgis -f /usr/share/postgresql/8.4/contrib/postgis.sql
 /usr/share/postgresql/8.4/contrib/spatial_ref_sys.sql
 If you could help me on this problem it would be very interesting for me.
 I do not know what I can do more. I am completely blocked on the
 development of my application because of this problem.
 Thank you very much in advance.
 Regards,
 Brice.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2662>
