[postgis-tickets] [PostGIS] #2665: Extension upgrade needs to selectively drop from extension aggregates and functions
PostGIS trac at osgeo.org
Fri Mar 7 08:42:01 PST 2014
functions
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.2
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by robe):
 Hmm what was I thinking.  I just noticed I only do it for raster.
 in extensions/postgis/makefile.in
 sql_bits/rtpostgis_upgrade.sql: ../../raster/rt_pg/rtpostgis_upgrade.sql
         sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' \
                 -e 's/DROP FUNCTION _rename_raster_tables();/ALTER
 EXTENSION ${EXTENSION} DROP FUNCTION _rename_raster_tables();DROP FUNCTION
 _rename_raster_tables();/g' \
                 -e 's/DROP FUNCTION _drop_st_samealignment();/ALTER
 EXTENSION ${EXTENSION} DROP FUNCTION _drop_st_samealignment();DROP
 FUNCTION _drop_st_samealignment();/g' \
                 -e 's/DROP CAST\(.*\)/SELECT
 postgis_extension_drop_if_exists('\''$(EXTENSION)'\'', '\''DROP CAST
 \1'\'');DROP CAST \1/' \
 I know sloppy.  But still I think we'll need to define logic that if you
 are running PostgreSQL 9.1+, you need to try to drop from postgis
 extension as well as whatever other drop you are doing and move this logic
 into the upgrade generation script.
 For 2.2 I 9.1 is our minimum version so we can just blindly try to drop
 from extension.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2665#comment:4>
