[postgis-tickets] [PostGIS] #2669: cunit warnings unsigned int ISO C90 assumption and extra tokens
PostGIS trac at osgeo.org
Sun Mar 9 14:17:01 PDT 2014
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
 I'm seeing some annoying warnings on winnie's compile.  They probably are
 harmless since they are on cunit, but could possibly cause false negatives
 cu_tree.c:19:24: warning: extra tokens at end of #include directive
 [enabled by default]
  #include "lwgeodetic.h";
 cu_tree.c:20:29: warning: extra tokens at end of #include directive
  #include "lwgeodetic_tree.h";
 cu_algorithm.c: In function 'test_geohash_point_as_int':
 cu_algorithm.c:889:2: warning: this decimal constant is unsigned only in
 ISO C90 [enabled by default]
   CU_ASSERT_EQUAL(gh, (unsigned int)3440103613);
 cu_algorithm.c:892:2: warning: this decimal constant is unsigned only in
   CU_ASSERT_EQUAL(gh, (unsigned int)3982480893);
 cu_algorithm.c:895:2: warning: this decimal constant is unsigned only in
   CU_ASSERT_EQUAL(gh, (unsigned int)4166944232);
 Note that winnie is running gcc 4.8.0 for 9.3 builds and I think gcc 4.8
 throws more warnings about using legacy constructs.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2669>
