[postgis-tickets] [PostGIS] #2672: twkb fails NULL crash test
PostGIS trac at osgeo.org
Sun Mar 9 21:28:40 PDT 2014
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Just ran thru garden 2.2 pot of tests and got a crasher on twkb.
 This is running on:
 POSTGIS="2.2.0dev r12313" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel. 4.8.0,
 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" RASTER PostgreSQL 9.3.3, compiled by Visual C++ build
 1600, 64-bit
 SELECT ST_AsTWKBAgg(foo1.the_geom, 3) As result FROM ((SELECT CAST(Null As
 geometry) As the_geom)) As foo1 LIMIT 3;
 errors with:
 server closed the connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
 psql:postgis_gardentest22.sql:272626: connection to server was lost
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2672>
