[postgis-tickets] [PostGIS] #2672: ST_AsTWKBAgg fails NULL crash test
PostGIS trac at osgeo.org
Mon Mar 10 12:21:52 PDT 2014
  Reporter:  robe     |       Owner:  nicklas
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 2.2.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by nicklas):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Thanks for catching this!
 Should be fixed in r12318
 It now ignores null inputs and aggregates the other.
 That behavior can be questioned since that means the corresponding ID will
 be just lost.
 The alternative I guess is putting some empty geometry in the aggregate,
 but I do not know if that is correct either. No big deal I guess.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2672#comment:3>
