[postgis-tickets] [PostGIS] #2671: twkb regression failure
PostGIS trac at osgeo.org
Mon Mar 10 20:08:20 PDT 2014
 Reporter:  robe     |       Owner:  nicklas
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
  twkb .. failed (diff expected obtained:
 /projects/postgis/tmp/2.2.0dev_pg9.2_geos3.4.2_gdal1.10.0w32/test_81_diff)
 --- twkb_expected       2014-03-10 17:15:42 -0400
 /projects/postgis/tmp/2.2.0dev_pg9.2_geos3.4.2_gdal1.10.0w32/test_81_out
 2014-03-10 23:03:41 -0400
 @@ -14,4 +14,4 @@
  GEOMETRYCOLLECTION(POINT(1 1),LINESTRING(2 2,3
 3))|024702410202420202020202
  GEOMETRYCOLLECTION(MULTIPOINT(1 1,2 2),POINT(78 -78),POLYGON((1 1,1 2,2
 2,2 1,1 1)))|0247034402020202024198019f0143010599019e010002020000010100
  MULTIPOINT(1 1,2 2)|035502060202040202
 -GEOMETRYCOLLECTION(MULTIPOINT(1 1,2 2),POINT(78 -78),POLYGON((1 1,1 2,2
 2,2 1,1
 1)))|0387035501c8439c019b015701bd08010599019e01000202000001010058010602410000410202
 +ERROR:  Output TWKB is not the same size as the allocated buffer
 (precalculated size:42, allocated size:31)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2671#comment:2>
