[postgis-tickets] [PostGIS] #2675: ST_Intersects() in WHERE clause misses results
PostGIS trac at osgeo.org
Wed Mar 12 13:34:12 PDT 2014
 Reporter:  xowap    |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.2
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by pramsey):
 I've found the source of this problem (yah, plane) but only got part way
 through the fix. Still unsure what caused the FLIPPING in your example
 though robe, the problem I found was just a straight up error in logic
 (poor handling of multi-* things and collections in the tree distance
 code) so the failures should be deterministic.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2675#comment:2>
