[postgis-tickets] [PostGIS] #2678: Build fails with multiple postgresql servers installed
PostGIS trac at osgeo.org
Tue Mar 18 09:03:51 PDT 2014
 Reporter:  strk       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.1.2
Component:  buildbots  |     Version:  2.1.x
 Keywords:             |
Comment(by strk):
 pg_config --version gives 9.3.3: https://travis-
 ci.org/postgis/postgis/builds/21026125#L679
 We should maybe check the version of the database we connect to and refuse
 to run "make check" for regress if the database version doesnt' match the
 built against version.
 In any case for travis it'd be better to only build against the installed
 version (9.1.1).
 I'll try that.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2678#comment:1>
