[postgis-tickets] [PostGIS] #2674: Another count mismatch postgis 2.0.4 to 2.1.2dev one less operator
PostGIS trac at osgeo.org
Fri Mar 21 23:49:06 PDT 2014
  Reporter:  robe                   |       Owner:  strk
      Type:  defect                 |      Status:  new
  Priority:  blocker                |   Milestone:  PostGIS 2.1.2
 Component:  build/upgrade/install  |     Version:  2.1.x
Resolution:                         |    Keywords:
Comment(by robe):
 Actually I see in the postgis 2.2 (trunk) there is logic to create the
 operators.  So this might be just a longer standing issue with the older
 upgrade routine (2.1 is not quite as advanced as 2.2. script) and I think
 in the past we never created new operators
 Unfortunately 2.2 has the issue with aggregate that its trying to drop
 _st_mapalgebra4unionfinal1(raster) so have to fix that one to drop from
 extension first before I can verify works fine in 2.2.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2674#comment:8>
