[postgis-tickets] [PostGIS] #2674: Another count mismatch postgis 2.0.4 to 2.1.2dev one less operator
PostGIS trac at osgeo.org
Mon Mar 24 05:55:55 PDT 2014
  Reporter:  robe                   |       Owner:  strk
      Type:  defect                 |      Status:  new
  Priority:  blocker                |   Milestone:  PostGIS 2.1.2
 Component:  build/upgrade/install  |     Version:  2.1.x
Resolution:                         |    Keywords:
Comment(by robe):
 CREATE EXTENSION postgis VERSION "2.0.4";
 ALTER EXTENSION postgis  UPDATE TO "2.1.2dev";
 I also tried installing with the scripts and upgrading with the scripts,
 though its more likely I missed a step there.
 I'm puzzled why I'm not getting the _st_mapalgebra4unionfinal1 drop error
 when upgrading to 2.1 (but get it going to 2.2) though since that was
 dropped in 2.1 and it looks like include script
 (sql_bits/remove_from_extension.sql.in) to remove functions from
 extensions has been removed in both the 2.1 and trunk branches
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2674#comment:10>
