[postgis-tickets] [PostGIS] #2674: Another count mismatch postgis 2.0.4 to 2.1.2dev one less operator
PostGIS trac at osgeo.org
Mon Mar 24 07:53:37 PDT 2014
  Reporter:  robe                   |       Owner:  strk
      Type:  defect                 |      Status:  new
  Priority:  blocker                |   Milestone:  PostGIS 2.1.2
 Component:  build/upgrade/install  |     Version:  2.1.x
Resolution:                         |    Keywords:
Comment(by strk):
 So 9.3 wasn't supported byt I installed in 9.1 and run_test.pl failed to
 find a problem:
 [strk at cdb:/usr/src/postgis/postgis/regress(svn-trunk)] ./run_test.pl
 --extension --upgrade-path 2.0.4--2.1.2dev -v
 /usr/src//postgis/postgis-2.1/regress/tickets.sql
 Upgrade path: 2.0.4 --> 2.1.2dev
 PATH is
 /home/strk/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
 Checking for shp2pgsql ... found
 Checking for pgsql2shp ... found
 TMPDIR is /tmp/pgis_reg
 Creating database 'postgis_reg'
 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis VERSION '2.0.4'
 Upgrading PostGIS in 'postgis_reg' using: ALTER EXTENSION postgis UPDATE
 TO '2.1.2dev'
 PostgreSQL 9.1.12 on x86_64-unknown-linux-gnu, compiled by gcc
 (Ubuntu/Linaro 4.8.1-10ubuntu8) 4.8.1, 64-bit
   Postgis 2.0.4 - r12336 - 2014-02-23 15:21:31
   scripts 2.1.2dev r12336
   GEOS: 3.4.3dev-CAPI-1.8.3 r3958
   PROJ: Rel. 4.7.1, 23 September 2009
 Running tests
  /usr/src//postgis/postgis-2.1/regress/tickets .. ok
  uninstall .. ok (3857)
 Run tests: 2
 Failed: 0
 The "uninstall" test checks that the number of objects in the database
 _before_ the initial install (2.0.4) is the same as the number of database
 objets _after_ the disinstall. How can we make run_test.pl catch the error
 you're talking about ? What should it check ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2674#comment:12>
