[postgis-tickets] [PostGIS] #2674: Another count mismatch postgis 2.0.4 to 2.1.2dev one less operator
PostGIS trac at osgeo.org
Mon Mar 24 10:50:59 PDT 2014
  Reporter:  robe                   |       Owner:  strk
      Type:  defect                 |      Status:  new
  Priority:  blocker                |   Milestone:  PostGIS 2.1.2
 Component:  build/upgrade/install  |     Version:  2.1.x
Resolution:                         |    Keywords:
Comment(by strk):
 Figured: I hadn't back-ported the postgis_upgrade.pl patch that reads the
 availability directly from the .sql file, so the new operators had to be
 explicitly listed in postgis_proc_upgrade.pl itself.
 Should be fixed as of r12341
 Trunk should be already working fine by reading from SQL, but I haven't
 double-checked.
 Testing this in a regression won't be easy in that lack of RASTER=RASTER
 would probably result in automatic cast to geometry and use of
 GEOMETRY=GEOMETRY instead...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2674#comment:17>
