[postgis-tickets] [PostGIS] #2665: Extension upgrade needs to selectively drop from extension aggregates and functions
PostGIS trac at osgeo.org
Wed Mar 26 02:19:22 PDT 2014
functions
  Reporter:  robe                   |       Owner:  strk
      Type:  defect                 |      Status:  closed
  Priority:  medium                 |   Milestone:  PostGIS 2.1.2
 Component:  build/upgrade/install  |     Version:  2.1.x
Resolution:  wontfix                |    Keywords:
Changes (by strk):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 Robe I need you to find an actual bug here, or it's a cleanup task.
 Functions are always created (create or replace being supported).
 Casts, according to your sed script, are only dropped _IF_ the drop is
 also found in the upgrade script, so I don't see a problem.
 Closing as won't fix, feel free to reopen/retarget/reassign
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2665#comment:6>
