[postgis-tickets] [PostGIS] #2684: can't upgrade from 2.1.1 to 2.1.2 with extensions
PostGIS trac at osgeo.org
Thu Mar 27 07:39:45 PDT 2014
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.1.2
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by strk):
 I think you should change the Makefile to use 21_minor.sql for 2.1.x to
 2.1.x extension upgrades.
 Will leave that to you as you were the original author of that Makefile,
 right ?
 In trunk it'll be easier as the upgrade script is one for all minor
 upgrades.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2684#comment:9>
