[postgis-tickets] [PostGIS] #2684: can't upgrade from 2.1.1 to 2.1.2 with extensions
PostGIS trac at osgeo.org
Fri Mar 28 04:19:08 PDT 2014
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.1.2
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by pramsey):
 Does
 make check RUNTESTFLAGS=--extension
 work for you? it does not for me, even with 2.1.1.
 up=# SELECT 'contains100', ST_contains('POLYGON((0 0, 0 10, 10 10, 10 0, 0
 0))', 'POINT(5 5)');
 ERROR:  function st_contains(unknown, unknown) is not unique
 I've confirmed this isn't a problem with the regression test, it's a
 problem with the extension install, by running one of the regression
 queries (the above one) manually on a extension-enabled database. There
 seem to be lots of others of these type-recognition errors for extension
 installs.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2684#comment:11>
