[postgis-tickets] [PostGIS] #2688: make check RUNTESTFLAGS=--extension can't run on debbie
PostGIS trac at osgeo.org
Fri Mar 28 04:35:58 PDT 2014
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.1.2
Component:  buildbots  |     Version:  2.1.x
 Keywords:             |
 strk,
 I was unable to get make check runtestflags to run on debbie so had to
 remark it out.
 Keeps on giving this error:
 psql: FATAL:  role "jenkins" does not exist
 Creating database 'postgis_reg'
 createdb: could not connect to database template1: FATAL:  role "jenkins"
 does not exist
 Preparing db 'postgis_reg' using 'CREATE EXTENSION'
 I don't know why this is an issue since I have a line
 export PGUSER=postgres
 and the regular regress in theory would be running into the same issue.
 Anyrate she pulls this script:
 http://svn.osgeo.org/postgis/buildbots/debian/scripts/postgis_regress.sh
 I remarked out the extension install piece since it wasn't working.
 Fill free to change it and then she should run it on next postgis regress
 run.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2688>
