[postgis-tickets] [PostGIS] #2723: failure to build against external json-c 0.12
PostGIS trac at osgeo.org
Fri May 2 02:09:03 PDT 2014
 Reporter:  landry   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
Comment(by robe):
 okay then I think for cleanness we should probably make 0.10+ a
 requirement for PostGIS 2.2 (especially since newer stable GDAL has that
 as a minimum too).  For 2.1 we'd need an uglier hack that supports older.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2723#comment:3>
