[postgis-tickets] [PostGIS] #2623: pgsql2shp creates a dbf with 0 records when the table only has a geometry column
PostGIS trac at osgeo.org
Fri May 2 17:34:35 PDT 2014
column
 Reporter:  winkey         |       Owner:  mcayland
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.2.0
Component:  loader/dumper  |     Version:  2.0.x
 Keywords:                 |
Changes (by robe):
  * owner:  pramsey => mcayland
  * component:  postgis => loader/dumper
Comment:
 what was I thinking code altready has an interator so can probably just
 use that as a dummy id if no fields present.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2623#comment:6>
