[postgis-tickets] [PostGIS] #2725: SIGSEGV in geos_intersects
PostGIS trac at osgeo.org
Tue May 6 00:32:52 PDT 2014
 Reporter:  lefty    |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
 Hello! We are trying to upgrade to PostgreSQL 9.3 & Postgis 2.1 and we are
 now blocked by a reproducible crash "in geos_intersects at
 lwgeom_geos.c:2624". Here is the strack trace:
 #0  0x00007f4942d9d946 in geos_intersects (fcinfo=0x1618600) at
 lwgeom_geos.c:2624
 #1  0x000000000058b01b in ExecMakeFunctionResult (fcache=0x1618590,
 econtext=0x1617a40, isNull=0x1619008 "", isDone=<optimized out>) at
 execQual.c:1927
 #2  0x0000000000586b36 in ExecEvalAnd (andExpr=<optimized out>,
 execQual.c:2767
 #3  0x000000000058d4f6 in ExecTargetList (isDone=0x7fff39325c1c,
 itemIsDone=0x1619120, isnull=0x1619008 "", values=0x1618ff0,
 econtext=0x1617a40,
     targetlist=0x16190f0) at execQual.c:5221
 #4  ExecProject (projInfo=<optimized out>, isDone=0x7fff39325c1c) at
 execQual.c:5436
 #5  0x000000000059e5fb in ExecResult (node=0x1617930) at nodeResult.c:155
 #6  0x00000000005866b8 in ExecProcNode (node=0x1617930) at
 execProcnode.c:372
 #7  0x0000000000583fe2 in ExecutePlan (dest=0x1611730,
 direction=<optimized out>, numberTuples=1, sendTuples=1 '\001',
 operation=CMD_SELECT,
     planstate=0x1617930, estate=0x1617820) at execMain.c:1395
 #8  standard_ExecutorRun (queryDesc=0x1613960, direction=<optimized
 out>, count=1) at execMain.c:303
 #9  0x0000000000591411 in postquel_getnext (es=<optimized out>,
 fcache=<optimized out>) at functions.c:844
 #10 fmgr_sql (fcinfo=<optimized out>) at functions.c:1140
 #11 0x0000000000589bd8 in ExecMakeFunctionResultNoSets
 (fcache=0x7f494441a170, econtext=0x7f4944419a90, isNull=0x7fff39325e2f
     at execQual.c:1993
 #12 0x000000000058d30f in ExecQual (qual=<optimized out>,
 econtext=0x7f4944419a90, resultForNull=0 '\000') at execQual.c:5123
 #13 0x000000000059763a in ExecHashJoin (node=0x7f4944419980) at
 nodeHashjoin.c:393
 #14 0x0000000000586598 in ExecProcNode (node=0x7f4944419980) at
 execProcnode.c:456
 #15 0x00000000005968c5 in MultiExecHash (node=0x7f49444190e0) at
 nodeHash.c:101
 #16 0x000000000059729b in ExecHashJoin (node=0x7f49444168f0) at
 nodeHashjoin.c:177
 #17 0x0000000000586598 in ExecProcNode (node=0x7f49444168f0) at
 execProcnode.c:456
 #18 0x0000000000597876 in ExecHashJoin (node=0x7f49444157d0) at
 nodeHashjoin.c:153
 #19 0x0000000000586598 in ExecProcNode (node=0x7f49444157d0) at
 execProcnode.c:456
 #20 0x0000000000597876 in ExecHashJoin (node=0x7f49444146b0) at
 nodeHashjoin.c:153
 #21 0x0000000000586598 in ExecProcNode (node=0x7f49444146b0) at
 execProcnode.c:456
 #22 0x000000000059f2e9 in ExecSort (node=0x7f4944414440) at nodeSort.c:103
 #23 0x0000000000586578 in ExecProcNode (node=0x7f4944414440) at
 execProcnode.c:467
 #24 0x000000000059b7f8 in ExecMergeJoin (node=0x1523a90) at
 nodeMergejoin.c:682
 #25 0x00000000005865a8 in ExecProcNode (node=0x1523a90) at
 execProcnode.c:452
 #26 0x000000000059f2e9 in ExecSort (node=0x1523820) at nodeSort.c:103
 #27 0x0000000000586578 in ExecProcNode (node=0x1523820) at
 execProcnode.c:467
 #28 0x0000000000599a68 in ExecLimit (node=0x1523580) at nodeLimit.c:91
 #29 0x00000000005864f8 in ExecProcNode (node=0x1523580) at
 execProcnode.c:499
 #30 0x0000000000583fe2 in ExecutePlan (dest=0x7f49444adf20,
 direction=<optimized out>, numberTuples=0, sendTuples=1 '\001',
     planstate=0x1523580, estate=0x1504520) at execMain.c:1395
 #31 standard_ExecutorRun (queryDesc=0x14a3df0, direction=<optimized
 out>, count=0) at execMain.c:303
 #32 0x000000000065a5f7 in PortalRunSelect (portal=0x14afaf0,
 forward=<optimized out>, count=0, dest=0x7f49444adf20) at pquery.c:944
 #33 0x000000000065b968 in PortalRun (portal=0x14afaf0,
 count=9223372036854775807, isTopLevel=1 '\001', dest=0x7f49444adf20,
 altdest=0x7f49444adf20,
     completionTag=0x7fff393267f0 "") at pquery.c:788
 #34 0x0000000000657cb3 in exec_simple_query (
     query_string=0x143fec0 "SELECT ST_AsGeoJson(geometry) AS
 jsongeometry, (v_parcely_g.id) AS id, (v_parcely_g.katuze_kod::text ||
 COALESCE(zdpaze_kod::te
 xt, druh_cislovani_par::text, '0')::text ||
 LPAD(kmenove_cislo_par::text,"...) at postgres.c:1046
 #35 PostgresMain (argc=<optimized out>, argv=<optimized out>,
 dbname=0x138c9b0 "sokolov", username=<optimized out>) at postgres.c:3959
 #36 0x0000000000616f48 in BackendRun (port=0x137f870) at postmaster.c:3614
 #37 BackendStartup (port=0x137f870) at postmaster.c:3304
 #38 0x00000000006175d6 in ServerLoop () at postmaster.c:1367
 #39 0x0000000000617ffc in PostmasterMain (argc=5, argv=<optimized out>)
 at postmaster.c:1127
 #40 0x00000000005b77ce in main (argc=5, argv=0x1360890) at main.c:199
 Query:
 SELECT ST_AsGeoJson(geometry) AS jsongeometry, (v_parcely_g.id) AS id,
 (v_parcely_g.katuze_kod::text || COALESCE(zdpaze_kod::text,
 druh_cislovani_par::text, '0')::text || LPAD(kmenove_cislo_par::text, 5,
 '0') || LPAD(COALESCE(poddeleni_cisla_par,'0')::text, 3, '0') ||
 COALESCE(dil_parcely,'0') ) AS vita, druh_cislovani_par,
 kmenove_cislo_par, poddeleni_cisla_par, vymera_parcely, d_pozemku,
 zp_vyuziti_poz, oprav_subjekty, pocet_vlastniku FROM v_parcely_g WHERE
 (ST_Intersects (geometry, GeomFromText('POINT(-867975.59044434
 -1014786.6774316)', (select ST_SRID(geometry) from v_parcely_g where
 ST_SRID(geometry) is not null LIMIT 1)))) ORDER BY druh_cislovani_par
 ASC, kmenove_cislo_par ASC, poddeleni_cisla_par ASC limit 1;
 Note: there is postgis 2.0 installed in that db as well and we did a soft-
 upgrade from it.
 Versions:
 postgresql - 9.3.4 (gentoo ebuild)[[BR]]
 postgis - 2.1.1 (gentoo ebuild), but tried 2.1.0 as well with the same
 result[[BR]]
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2725>
