[postgis-tickets] [PostGIS] #2730: topology uninstall with extension doesn't uninstall everything
PostGIS trac at osgeo.org
Fri May 9 01:39:26 PDT 2014
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.1.3
Component:  topology  |     Version:  2.1.x
 Keywords:            |
 I'm getting this error on winnie when she builds with make extension run:
 Checking for pgsql2shp ... found
 TMPDIR is /projects/postgis/tmp/2.1.3dev_pg9.2_geos3.4.2_gdal1.10.0w64
 Creating database 'postgis_reg'
 Preparing db 'postgis_reg' using 'CREATE EXTENSION'
 PostgreSQL 9.2.4 on x86_64-w64-mingw32, compiled by gcc.exe (GCC) 4.5.4
 20111030 (prerelease) [svn/rev.180676 - mingw-w64/oz], 64-bit
   Postgis 2.1.3dev
  - r12521
  - 2014-05-09 06:46:56
   GEOS: 3.4.2-CAPI-1.8.2 r0
   PROJ: Rel. 4.8.0, 6 March 2012
 Running tests
  regress/legacy_validate .. ok
  regress/legacy_predicate .. ok
  regress/legacy_invalid .. ok
  regress/sqlmm .. ok
  regress/legacy_query .. ok
  regress/addnode .. ok
  regress/addedge .. ok
  regress/addface .. ok
  regress/addface2.5d .. ok
  regress/addtopogeometrycolumn .. ok
  regress/polygonize .. ok
  regress/st_addisoedge .. ok
  regress/st_addisonode .. ok
  regress/st_addedgemodface .. ok
  regress/st_addedgenewfaces .. ok
  regress/st_changeedgegeom .. ok
  regress/st_createtopogeo .. ok
  regress/st_getfacegeometry .. ok
  regress/st_getfaceedges .. ok
  regress/st_modedgeheal .. ok
  regress/st_modedgesplit .. ok
  regress/st_newedgeheal .. ok
  regress/st_newedgessplit .. ok
  regress/st_remedgenewface .. ok
  regress/st_remedgemodface .. ok
  regress/st_simplify .. ok
  regress/topoelement .. ok
  regress/topoelementarray_agg .. ok
  regress/topogeo_addlinestring .. ok
  regress/topogeo_addpoint .. ok
  regress/topogeo_addpolygon .. ok
  regress/topogeometry_type .. ok
  regress/topojson .. ok
  regress/topo2.5d .. ok
  regress/totopogeom .. ok
  regress/droptopology .. ok
  regress/copytopology .. ok
  regress/createtopogeom .. ok
  regress/createtopology .. ok
  regress/gml .. ok
  regress/getnodebypoint .. ok
  regress/getedgebypoint .. ok
  regress/getfacebypoint .. ok
  regress/getringedges .. ok
  regress/gettopogeomelements .. ok
  regress/layertrigger .. ok
  regress/validatetopology .. ok
  uninstall .. failed (Object count pre-install (4061
 ) != post-uninstall (4062
 Run tests: 48
 Failed: 1
 make[2]: *** [check] Error 1
 make[2]: Leaving directory `/projects/postgis/branches/2.1/topology/test'
 make[1]: *** [check] Error 2
 make[1]: Leaving directory `/projects/postgis/branches/2.1/topology'
 make: *** [check] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2730>
