[postgis-tickets] [PostGIS] #2731: Both debbie and winnie registering success when they have failures
PostGIS trac at osgeo.org
Fri May 9 01:41:21 PDT 2014
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  Management 2.0
Component:  buildbots  |     Version:  2.1.x
 Keywords:             |
 Haven't figured out what I did to screw up the scripts but on both winnie
 and debbie, they are no longer registering jenkins failures when they
 clearly have failures.
 Such as the case with #2730
 it registered as success when it was clearly a failure when you look at
 the logs
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2731>
