[postgis-tickets] [PostGIS] #2726: [raster]: POSTGIS_GDAL_ENABLED_DRIVERS not picking up all drivers listed
PostGIS trac at osgeo.org
Fri May 9 12:29:31 PDT 2014
 Reporter:  robe     |       Owner:  dustymugs
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.3
Component:  raster   |     Version:  2.1.x
 Keywords:  windows  |
Comment(by robe):
 okee with more output
 When I run:
 @SET POSTGIS_GDAL_ENABLED_DRIVERS="GTiff EHdr PNG XYZ JPEG GIF"
 SELECT short_name FROM ST_GDALDrivers();
 PNG
 JPEG
 EHdr
 XYZ
 The debug out notice looks like:
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:112] GDAL_SKIP =
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:113] enabled_drivers =
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:161] driver count =
 102
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[0] = VRT
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[1] =
 GTiff
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:171] GTiff found in
 gdal_enabled_drivers
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[2] = NITF
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[3] =
 RPFTOC
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[4] =
 ECRGTOC
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[5] = HFA
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[6] =
 SAR_CEOS
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[7] = CEOS
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[8] =
 JAXAPALSAR
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[9] = GFF
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[10] =
 ELAS
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[11] = AIG
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[12] =
 AAIGrid
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[13] =
 GRASSASCIIGrid
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[14] =
 SDTS
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[15] =
 DTED
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[16] = PNG
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:171] PNG found in
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:176] PNG found
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[17] =
 JPEG
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:171] JPEG found in
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:176] JPEG found
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[18] = MEM
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[19] =
 JDEM
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[20] = GIF
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:171] GIF found in
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[21] =
 BIGGIF
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[22] =
 ESAT
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[23] = BSB
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[24] = XPM
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[25] = BMP
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[26] =
 DIMAP
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[27] =
 AirSAR
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[28] = RS2
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[29] =
 PCIDSK
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[30] =
 PCRaster
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[31] =
 ILWIS
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[32] = SGI
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[33] =
 SRTMHGT
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[34] =
 Leveller
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[35] =
 Terragen
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[36] =
 ISIS3
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[37] =
 ISIS2
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[38] = PDS
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[39] = TIL
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[40] = ERS
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[41] = L1B
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[42] = FIT
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[43] =
 GRIB
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[44] = RMF
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[45] =
 MSGN
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[46] = RST
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[47] =
 INGR
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[48] =
 GSAG
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[49] =
 GSBG
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[50] =
 GS7BG
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[51] =
 COSAR
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[52] = TSX
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[53] =
 COASP
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[54] = R
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[55] = MAP
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[56] = PNM
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[57] =
 DOQ1
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[58] =
 DOQ2
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[59] =
 ENVI
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[60] =
 EHdr
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:171] EHdr found in
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:176] EHdr found
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[61] =
 GenBin
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[62] =
 PAux
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[63] = MFF
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[64] =
 MFF2
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[65] =
 FujiBAS
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[66] = GSC
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[67] =
 FAST
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[68] = BT
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[69] = LAN
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[70] = CPG
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[71] = IDA
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[72] = NDF
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[73] = EIR
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[74] =
 DIPEx
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[75] = LCP
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[76] = GTX
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[77] =
 LOSLAS
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[78] =
 NTv2
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[79] =
 CTable2
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[80] =
 ACE2
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[81] =
 SNODAS
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[82] = ARG
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[83] = RIK
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[84] =
 USGSDEM
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[85] = GXF
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[86] =
 NWT_GRD
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[87] =
 NWT_GRC
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[88] =
 ADRG
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[89] = SRP
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[90] = BLX
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[91] =
 SAGA
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[92] =
 KMLSUPEROVERLAY
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[93] = XYZ
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:171] XYZ found in
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:176] XYZ found
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[94] = HF2
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[95] = PDF
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[96] = OZI
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[97] = CTG
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[98] =
 E00GRID
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[99] =
 ZMap
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[100] =
 NGSGEOID
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:165] drv_set[101] =
 IRIS
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:219] gdal_skip = VRT
 GTiff NITF RPFTOC ECRGTOC HFA SAR_CEOS CEOS JAXAPALSAR GFF ELAS AIG
 AAIGrid GRASSASCIIGrid SDTS DTED MEM JDEM GIF BIGGIF ESAT BSB XPM BMP
 DIMAP AirSAR RS2 PCIDSK PCRaster ILWIS SGI SRTMHGT Leveller Terragen ISIS3
 ISIS2 PDS TIL ERS L1B FIT GRIB RMF MSGN RST INGR GSAG GSBG GS7BG COSAR TSX
 COASP R MAP PNM DOQ1 DOQ2 ENVI GenBin PAux MFF MFF2 FujiBAS GSC FAST BT
 LAN CPG IDA NDF EIR DIPEx LCP GTX LOSLAS NTv2 CTable2 ACE2 SNODAS ARG RIK
 USGSDEM GXF NWT_GRD NWT_GRC ADRG SRP BLX SAGA KMLSUPEROVERLAY HF2 PDF OZI
 CTG E00GRID ZMap NGSGEOID IRIS
 NOTICE:  [rt_pg.c:rtpg_assignHookGDALEnabledDrivers:228] GDAL_SKIP = VRT
 NOTICE:  [rt_api.c:rt_raster_gdal_drivers:8997] rt_raster_gdal_driver:
 driver PNG (0) supports CreateCopy() and VirtualIO()
 driver JPEG (1) supports CreateCopy() and VirtualIO()
 driver EHdr (2) supports CreateCopy() and VirtualIO()
 driver XYZ (3) supports CreateCopy() and VirtualIO()
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11708] 4 drivers returned
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11748] Result 0
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11757] Result 0, Index 0
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11758] Result 0, Short Name PNG
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11759] Result 0, Full Name
 Portable Network Graphics
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11748] Result 1
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11757] Result 1, Index 1
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11758] Result 1, Short Name JPEG
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11759] Result 1, Full Name JPEG
 JFIF
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11748] Result 2
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11757] Result 2, Index 2
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11758] Result 2, Short Name EHdr
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11759] Result 2, Full Name ESRI
 .hdr Labelled
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11748] Result 3
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11757] Result 3, Index 3
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11758] Result 3, Short Name XYZ
 NOTICE:  [rt_pg.c:RASTER_getGDALDrivers:11759] Result 3, Full Name ASCII
 Gridded XYZ
 Total query runtime: 34 ms.
 4 rows retrieved.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2726#comment:8>
