[postgis-tickets] [PostGIS] #2732: gserialized_estimate crashes under mingw64 windows when compiled with --enabled-debug
PostGIS trac at osgeo.org
Mon May 12 12:54:10 PDT 2014
--enabled-debug
 Reporter:  robe              |       Owner:  pramsey
     Type:  defect            |      Status:  new
 Priority:  medium            |   Milestone:  PostGIS 2.1.3
Component:  postgis           |     Version:  2.1.x
 Keywords:  windows, mingw64  |
Comment(by robe):
 For the record, I was testing with skeleton tables, not sure it makes a
 difference:
 CREATE EXTENSION postgis;
 CREATE EXTENSION fuzzystrmatch;
 CREATE EXTENSION postgis_tiger_geocoder;
 After all installed reconnect and run this query:
  SELECT pprint_addy(addy), st_astext(geomout), rating FROM
   geocode_intersection('Broadway', 'Houston St', 'NY', 'New York',
 '10012');
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2732#comment:2>
