[postgis-tickets] [PostGIS] #2723: failure to build against external json-c 0.12
PostGIS trac at osgeo.org
Tue May 13 02:08:18 PDT 2014
 Reporter:  landry   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.3
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
Changes (by mwanner):
  * milestone:  PostGIS 2.2.0 => PostGIS 2.1.3
Comment:
 I run into the same issue on Debian, where I need the postgis package to
 compile against both, old and new json(-c). While r12347 (fixing #2539) is
 a step in the right direction, it's clearly not sufficient.
 I've attached the patch that I'm going to use for Debian to allow postgis
 to compile if a new json-c is installed.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2723#comment:4>
