[postgis-tickets] [PostGIS] #2734: TIGER geocoder gives no results with omitted zipcode
PostGIS trac at osgeo.org
Tue May 13 12:43:35 PDT 2014
 Reporter:  futuraprime     |       Owner:  robe
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:
Component:  tiger geocoder  |     Version:  2.1.x
 Keywords:                  |
 I'm using the TIGER geocoder (2013 data, PostGIS 2.1, Postgres 9.3) to
 geocode intersections in New York City, but I'm finding that if I omit the
 zip code, I almost never get a match. So, for example...
 ny_tiger=# SELECT pprint_addy(addy), st_astext(geomout), rating FROM
   geocode_intersection('Broadway', 'Houston St', 'NY', 'New York',
 '10012');
        pprint_addy            |          st_astext          | rating
  607 Broadway, New York, NY 10012 | POINT(-73.996772 40.725432) |      0
  604 Broadway, New York, NY 10012 | POINT(-73.996772 40.725432) |      0
  609 Broadway, New York, NY 10012 | POINT(-73.996772 40.725432) |      0
  606 Broadway, New York, NY 10012 | POINT(-73.996772 40.725432) |      0
 (4 rows)
 but...
   geocode_intersection('Broadway', 'Houston St', 'NY', 'New York');
 (0 rows)
 Regina on GIS StackExchange (http://gis.stackexchange.com/questions/95511
 /tiger-geocoder-not-matching-intersections-without-zip) suggests that this
 is a bug, and requested I report it here.
 The debug trace she requested is:
 NOTICE:  var_zip:
 '{10001,10002,10003,10004,10005,10006,10007,10009,10010,10011,10012,10013,10014,10016,10017,10018,10019,10020,10021,10022,10023,10024,10025,10026,10027,10028,10029,10030,10031,10032,10033,10034,10035,10036,10037,10038,10039,10040,10044,10065,10069,10075,10107,10110,10112,10118,10119,10120,10123,10128,10166,10169,10175,10270,10278,10279,10280,10281,10282,10285,10301,10301,10302,10303,10304,10305,10306,10307,10308,10309,10310,10312,10314,10451,10452,10453,10454,10455,10456,10457,10458,10459,10460,10461,10462,10463,10463,10464,10464,10465,10466,10466,10467,10468,10469,10470,10470,10471,10472,10473,10474,10475,10550,10550,10704,10704,10705,10705,11001,11001,11003,11004,11040,11101,11102,11103,11104,11105,11106,11109,11201,11203,11204,11205,11206,11207,11207,11208,11208,11209,11210,11211,11212,11213,11214,11215,11216,11217,11218,11219,11219,11220,11221,11222,11223,11223,11224,11225,11226,11228,11229,11230,11231,11232,11233,11234,11235,11236,11237,11237,11238,11239,11249,11252,11354,11355,11356,11357,11358,11359,11360,11361,11362,11363,11364,11365,11366,11367,11368,11369,11370,11372,11373,11374,11375,11377,11378,11379,11385,11385,11411,11412,11413,11414,11414,11415,11416,11416,11417,11417,11418,11419,11420,11421,11421,11422,11422,11423,11426,11426,11427,11428,11428,11429,11429,11430,11432,11433,11434,11435,11436,11580,11580,11691,11691,11692,11693,11694,11695,11697}',
 city: 'New York'
 NOTICE:  sql:
     WITH
         a1 AS (SELECT f.*, addr.fromhn, addr.tohn, addr.side , addr.zip
                                 FROM (SELECT * FROM featnames
                                                         WHERE statefp =
 '36' AND ( lower(name) = 'broadway'   or  lower(fullname) LIKE 'broadway '
 || '%' ))  AS f LEFT JOIN (SELECT * FROM addr WHERE addr.statefp = '36')
 As addr ON (addr.tlid = f.tlid AND addr.statefp = f.statefp)
                                         WHERE
 '{10001,10002,10003,10004,10005,10006,10007,10009,10010,10011,10012,10013,10014,10016,10017,10018,10019,10020,10021,10022,10023,10024,10025,10026,10027,10028,10029,10030,10031,10032,10033,10034,10035,10036,10037,10038,10039,10040,10044,10065,10069,10075,10107,10110,10112,10118,10119,10120,10123,10128,10166,10169,10175,10270,10278,10279,10280,10281,10282,10285,10301,10301,10302,10303,10304,10305,10306,10307,10308,10309,10310,10312,10314,10451,10452,10453,10454,10455,10456,10457,10458,10459,10460,10461,10462,10463,10463,10464,10464,10465,10466,10466,10467,10468,10469,10470,10470,10471,10472,10473,10474,10475,10550,10550,10704,10704,10705,10705,11001,11001,11003,11004,11040,11101,11102,11103,11104,11105,11106,11109,11201,11203,11204,11205,11206,11207,11207,11208,11208,11209,11210,11211,11212,11213,11214,11215,11216,11217,11218,11219,11219,11220,11221,11222,11223,11223,11224,11225,11226,11228,11229,11230,11231,11232,11233,11234,11235,11236,11237,11237,11238,11239,11249,11252,11354,11355,11356,11357,11358,11359,11360,11361,11362,11363,11364,11365,11366,11367,11368,11369,11370,11372,11373,11374,11375,11377,11378,11379,11385,11385,11411,11412,11413,11414,11414,11415,11416,11416,11417,11417,11418,11419,11420,11421,11421,11422,11422,11423,11426,11426,11427,11428,11428,11429,11429,11430,11432,11433,11434,11435,11436,11580,11580,11691,11691,11692,11693,11694,11695,11697}'::text[]
 IS NULL OR addr.zip =
 ANY('{10001,10002,10003,10004,10005,10006,10007,10009,10010,10011,10012,10013,10014,10016,10017,10018,10019,10020,10021,10022,10023,10024,10025,10026,10027,10028,10029,10030,10031,10032,10033,10034,10035,10036,10037,10038,10039,10040,10044,10065,10069,10075,10107,10110,10112,10118,10119,10120,10123,10128,10166,10169,10175,10270,10278,10279,10280,10281,10282,10285,10301,10301,10302,10303,10304,10305,10306,10307,10308,10309,10310,10312,10314,10451,10452,10453,10454,10455,10456,10457,10458,10459,10460,10461,10462,10463,10463,10464,10464,10465,10466,10466,10467,10468,10469,10470,10470,10471,10472,10473,10474,10475,10550,10550,10704,10704,10705,10705,11001,11001,11003,11004,11040,11101,11102,11103,11104,11105,11106,11109,11201,11203,11204,11205,11206,11207,11207,11208,11208,11209,11210,11211,11212,11213,11214,11215,11216,11217,11218,11219,11219,11220,11221,11222,11223,11223,11224,11225,11226,11228,11229,11230,11231,11232,11233,11234,11235,11236,11237,11237,11238,11239,11249,11252,11354,11355,11356,11357,11358,11359,11360,11361,11362,11363,11364,11365,11366,11367,11368,11369,11370,11372,11373,11374,11375,11377,11378,11379,11385,11385,11411,11412,11413,11414,11414,11415,11416,11416,11417,11417,11418,11419,11420,11421,11421,11422,11422,11423,11426,11426,11427,11428,11428,11429,11429,11430,11432,11433,11434,11435,11436,11580,11580,11691,11691,11692,11693,11694,11695,11697}'::text[])
 OR addr.zip IS NULL
                                 ORDER BY CASE WHEN lower(f.fullname) =
 'broadway ' THEN 0 ELSE 1 END
                                 LIMIT 5000
         a2 AS (SELECT f.*, addr.fromhn, addr.tohn, addr.side , addr.zip
                                                         WHERE statefp =
 '36' AND ( lower(name) = 'houston'  or lower(fullname) LIKE 'houston st'
 || '%' ) )  AS f LEFT JOIN (SELECT * FROM addr WHERE addr.statefp = '36')
 AS addr ON (addr.tlid = f.tlid AND addr.statefp = f.statefp)
                                         WHERE
 or addr.zip IS NULL
                         ORDER BY CASE WHEN lower(f.fullname) = 'houston
 st' THEN 0 ELSE 1 END
                                 LIMIT 5000
          e1 AS (SELECT e.the_geom, e.tnidf, e.tnidt, a.*,
                                 CASE WHEN a.side = 'L' THEN e.tfidl ELSE
 e.tfidr END AS tfid
                                 FROM a1 As a
                                         INNER JOIN  edges AS e ON
 (e.statefp = a.statefp AND a.tlid = e.tlid)
                                 WHERE e.statefp = '36'
                                 ORDER BY CASE WHEN lower(a.name) =
 'houston' THEN 0 ELSE 1 END + CASE WHEN lower(e.fullname) = 'houston st'
 THEN 0 ELSE 1 END
                                 LIMIT 1000) ,
         e2 AS (SELECT e.the_geom, e.tnidf, e.tnidt, a.*,
 e.tfidr END AS tfid
                                 FROM (SELECT * FROM edges WHERE statefp =
 '36') AS e INNER JOIN a2 AS a ON (e.statefp = a.statefp AND a.tlid =
 e.tlid)
                                         INNER JOIN e1 ON (e.statefp =
 e1.statefp AND ST_Intersects(e.the_geom, e1.the_geom)
                                         AND ARRAY[e.tnidf, e.tnidt] &&
 ARRAY[e1.tnidf, e1.tnidt] )
                                 WHERE (lower(e.fullname) = 'houston st' or
 lower(a.name) LIKE 'houston' || '%')
 THEN 0 ELSE 1 END
                                 LIMIT 100
         segs AS (SELECT DISTINCT ON(e1.tlid, e1.side)
                    CASE WHEN e1.tnidf = e2.tnidf OR e1.tnidf = e2.tnidt
 THEN
                                 e1.fromhn
                             ELSE
                                 e1.tohn END As address, e1.predirabrv As
 fedirp, COALESCE(e1.prequalabr || ' ','' ) || e1.name As fename,
                              COALESCE(e1.suftypabrv,e1.pretypabrv)  As
 fetype, e1.sufdirabrv AS fedirs,
                                p.name As place, e1.zip,
 e2.tnidt THEN
 ST_StartPoint(ST_GeometryN(ST_Multi(e1.the_geom),1))
                              ELSE
 ST_EndPoint(ST_GeometryN(ST_Multi(e1.the_geom),1)) END AS geom ,
                                 CASE WHEN lower(p.name) = 'new york' THEN
 0 ELSE 1 END
                                 + levenshtein_ignore_case(p.name, 'new
 york')
                                 + levenshtein_ignore_case(e1.name ||
 COALESCE(' ' || e1.sufqualabr, ''),'broadway') +
                                 CASE WHEN e1.fullname = 'broadway ' THEN 0
 ELSE levenshtein_ignore_case(e1.fullname, 'broadway ') END +
                                 + levenshtein_ignore_case(e2.name ||
 COALESCE(' ' || e2.sufqualabr, ''),'houston')
                                 AS a_rating
                     FROM e1
                             INNER JOIN e2 ON (
                                     ST_Intersects(e1.the_geom,
 e2.the_geom)  )
                              INNER JOIN (SELECT * FROM faces WHERE statefp
 = '36') As fa1 ON (e1.tfid = fa1.tfid  )
                           LEFT JOIN place AS p ON (fa1.placefp = p.placefp
 AND p.statefp = '36' )
                        ORDER BY e1.tlid, e1.side, a_rating LIMIT 10*4 )
     SELECT address, fedirp , fename, fetype,fedirs,place, zip , geom,
 a_rating
         FROM segs ORDER BY a_rating LIMIT  10
 (0 rows)
 Thanks,[[BR]]
 Evan
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2734>
