[postgis-tickets] [PostGIS] #2734: TIGER geocoder gives no results with omitted zipcode
PostGIS trac at osgeo.org
Tue May 13 22:27:11 PDT 2014
 Reporter:  futuraprime     |       Owner:  robe
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.2.0
Component:  tiger geocoder  |     Version:  2.1.x
 Keywords:                  |
Comment(by robe):
 Evan,
 So what I was saying -- might as well say it here too for completeness.
 From the debugged output, it looks like the 10012 zip is in the check so
 I'm feeling more and more that its the limits being set.
 Try running the debugged sql output: Except change the LIMIT 5000 to
 something like LIMIT 10000 and LIMIT 1000 to like LIMIT 5000 and LIMIT 100
 to something like LIMIT 1000
 So basically try running this query:
     WITH
         a1 AS (SELECT f.*, addr.fromhn, addr.tohn, addr.side , addr.zip
                                 FROM (SELECT * FROM featnames
                                                         WHERE statefp =
 '36' AND ( lower(name) = 'broadway'   or  lower(fullname) LIKE 'broadway '
 || '%' ))  AS f LEFT JOIN (SELECT * FROM addr WHERE addr.statefp = '36')
 As addr ON (addr.tlid = f.tlid AND addr.statefp = f.statefp)
                                         WHERE
 '{10001,10002,10003,10004,10005,10006,10007,10009,10010,10011,10012,10013,10014,10016,10017,10018,10019,10020,10021,10022,10023,10024,10025,10026,10027,10028,10029,10030,10031,10032,10033,10034,10035,10036,10037,10038,10039,10040,10044,10065,10069,10075,10107,10110,10112,10118,10119,10120,10123,10128,10166,10169,10175,10270,10278,10279,10280,10281,10282,10285,10301,10301,10302,10303,10304,10305,10306,10307,10308,10309,10310,10312,10314,10451,10452,10453,10454,10455,10456,10457,10458,10459,10460,10461,10462,10463,10463,10464,10464,10465,10466,10466,10467,10468,10469,10470,10470,10471,10472,10473,10474,10475,10550,10550,10704,10704,10705,10705,11001,11001,11003,11004,11040,11101,11102,11103,11104,11105,11106,11109,11201,11203,11204,11205,11206,11207,11207,11208,11208,11209,11210,11211,11212,11213,11214,11215,11216,11217,11218,11219,11219,11220,11221,11222,11223,11223,11224,11225,11226,11228,11229,11230,11231,11232,11233,11234,11235,11236,11237,11237,11238,11239,11249,11252,11354,11355,11356,11357,11358,11359,11360,11361,11362,11363,11364,11365,11366,11367,11368,11369,11370,11372,11373,11374,11375,11377,11378,11379,11385,11385,11411,11412,11413,11414,11414,11415,11416,11416,11417,11417,11418,11419,11420,11421,11421,11422,11422,11423,11426,11426,11427,11428,11428,11429,11429,11430,11432,11433,11434,11435,11436,11580,11580,11691,11691,11692,11693,11694,11695,11697}'::text[]
 IS NULL OR addr.zip =
 ANY('{10001,10002,10003,10004,10005,10006,10007,10009,10010,10011,10012,10013,10014,10016,10017,10018,10019,10020,10021,10022,10023,10024,10025,10026,10027,10028,10029,10030,10031,10032,10033,10034,10035,10036,10037,10038,10039,10040,10044,10065,10069,10075,10107,10110,10112,10118,10119,10120,10123,10128,10166,10169,10175,10270,10278,10279,10280,10281,10282,10285,10301,10301,10302,10303,10304,10305,10306,10307,10308,10309,10310,10312,10314,10451,10452,10453,10454,10455,10456,10457,10458,10459,10460,10461,10462,10463,10463,10464,10464,10465,10466,10466,10467,10468,10469,10470,10470,10471,10472,10473,10474,10475,10550,10550,10704,10704,10705,10705,11001,11001,11003,11004,11040,11101,11102,11103,11104,11105,11106,11109,11201,11203,11204,11205,11206,11207,11207,11208,11208,11209,11210,11211,11212,11213,11214,11215,11216,11217,11218,11219,11219,11220,11221,11222,11223,11223,11224,11225,11226,11228,11229,11230,11231,11232,11233,11234,11235,11236,11237,11237,11238,11239,11249,11252,11354,11355,11356,11357,11358,11359,11360,11361,11362,11363,11364,11365,11366,11367,11368,11369,11370,11372,11373,11374,11375,11377,11378,11379,11385,11385,11411,11412,11413,11414,11414,11415,11416,11416,11417,11417,11418,11419,11420,11421,11421,11422,11422,11423,11426,11426,11427,11428,11428,11429,11429,11430,11432,11433,11434,11435,11436,11580,11580,11691,11691,11692,11693,11694,11695,11697}'::text[])
 OR addr.zip IS NULL
                                 ORDER BY CASE WHEN lower(f.fullname) =
 'broadway ' THEN 0 ELSE 1 END
                                 LIMIT 10000
         a2 AS (SELECT f.*, addr.fromhn, addr.tohn, addr.side , addr.zip
                                                         WHERE statefp =
 '36' AND ( lower(name) = 'houston'  or lower(fullname) LIKE 'houston st'
 || '%' ) )  AS f LEFT JOIN (SELECT * FROM addr WHERE addr.statefp = '36')
 AS addr ON (addr.tlid = f.tlid AND addr.statefp = f.statefp)
                                         WHERE
 or addr.zip IS NULL
                         ORDER BY CASE WHEN lower(f.fullname) = 'houston
 st' THEN 0 ELSE 1 END
                                 LIMIT 10000
          e1 AS (SELECT e.the_geom, e.tnidf, e.tnidt, a.*,
                                 CASE WHEN a.side = 'L' THEN e.tfidl ELSE
 e.tfidr END AS tfid
                                 FROM a1 As a
                                         INNER JOIN  edges AS e ON
 (e.statefp = a.statefp AND a.tlid = e.tlid)
                                 WHERE e.statefp = '36'
                                 ORDER BY CASE WHEN lower(a.name) =
 'houston' THEN 0 ELSE 1 END + CASE WHEN lower(e.fullname) = 'houston st'
 THEN 0 ELSE 1 END
                                 LIMIT 5000) ,
         e2 AS (SELECT e.the_geom, e.tnidf, e.tnidt, a.*,
 e.tfidr END AS tfid
                                 FROM (SELECT * FROM edges WHERE statefp =
 '36') AS e INNER JOIN a2 AS a ON (e.statefp = a.statefp AND a.tlid =
 e.tlid)
                                         INNER JOIN e1 ON (e.statefp =
 e1.statefp AND ST_Intersects(e.the_geom, e1.the_geom)
                                         AND ARRAY[e.tnidf, e.tnidt] &&
 ARRAY[e1.tnidf, e1.tnidt] )
                                 WHERE (lower(e.fullname) = 'houston st' or
 lower(a.name) LIKE 'houston' || '%')
 THEN 0 ELSE 1 END
                                 LIMIT 1000
         segs AS (SELECT DISTINCT ON(e1.tlid, e1.side)
                    CASE WHEN e1.tnidf = e2.tnidf OR e1.tnidf = e2.tnidt
 THEN
                                 e1.fromhn
                             ELSE
                                 e1.tohn END As address, e1.predirabrv As
 fedirp, COALESCE(e1.prequalabr || ' ','' ) || e1.name As fename,
                              COALESCE(e1.suftypabrv,e1.pretypabrv)  As
 fetype, e1.sufdirabrv AS fedirs,
                                p.name As place, e1.zip,
 e2.tnidt THEN
 ST_StartPoint(ST_GeometryN(ST_Multi(e1.the_geom),1))
                              ELSE
 ST_EndPoint(ST_GeometryN(ST_Multi(e1.the_geom),1)) END AS geom ,
                                 CASE WHEN lower(p.name) = 'new york' THEN
 0 ELSE 1 END
                                 + levenshtein_ignore_case(p.name, 'new
 york')
                                 + levenshtein_ignore_case(e1.name ||
 COALESCE(' ' || e1.sufqualabr, ''),'broadway') +
                                 CASE WHEN e1.fullname = 'broadway ' THEN 0
 ELSE levenshtein_ignore_case(e1.fullname, 'broadway ') END +
                                 + levenshtein_ignore_case(e2.name ||
 COALESCE(' ' || e2.sufqualabr, ''),'houston')
                                 AS a_rating
                     FROM e1
                             INNER JOIN e2 ON (
                                     ST_Intersects(e1.the_geom,
 e2.the_geom)  )
                              INNER JOIN (SELECT * FROM faces WHERE statefp
 = '36') As fa1 ON (e1.tfid = fa1.tfid  )
                           LEFT JOIN place AS p ON (fa1.placefp = p.placefp
 AND p.statefp = '36' )
                        ORDER BY e1.tlid, e1.side, a_rating LIMIT 10*4 )
     SELECT address, fedirp , fename, fetype,fedirs,place, zip , geom,
 a_rating
         FROM segs ORDER BY a_rating LIMIT  10
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2734#comment:2>
