[postgis-tickets] [PostGIS] #2539: Check for json-c/json.h presence/usability before json/json.h
PostGIS trac at osgeo.org
Thu May 15 10:08:10 PDT 2014
  Reporter:  mwtoews      |       Owner:  pramsey
      Type:  enhancement  |      Status:  reopened
  Priority:  medium       |   Milestone:  PostGIS 2.1.2
 Component:  postgis      |     Version:  2.1.x
Resolution:               |    Keywords:
Changes (by kzalewski):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Although detection of json-c/json.h is now working during the configure
 stage, compilation of PostGIS 2.1.2 still fails when using json-c 0.12.
 The file liblwgeom/lwin_geojson.c contains the following headers:
 #include <json/json.h>
 #include <json/json_object_private.h>
 which yields this compilation error:
 libtool: compile:  gcc -O2 -fPIC -fPIC -DPIC -Wall -Wmissing-prototypes
 -I/usr/include -c lwin_geojson.c  -fPIC -DPIC -o .libs/lwin_geojson.o
 lwin_geojson.c:20:23: fatal error: json/json.h: No such file or directory
 compilation terminated.
 In addition, once the #include lines are changed to <json-c/json.h> and
 <json-c/json_object_private.h>, there is an additional compilation error:
 lwin_geojson.c: In function 'parse_geojson_coord':
 lwin_geojson.c:71:6: warning: unused variable 'iType' [-Wunused-variable]
 lwin_geojson.c: In function 'lwgeom_from_geojson':
 lwin_geojson.c:515:43: error: 'json_tokener_errors' undeclared (first use
 in this function)
 lwin_geojson.c:515:43: note: each undeclared identifier is reported only
 once for each function it appears in
 The json_tokener_errors[] array has been replaced in json-c 0.12 with a
 function json_tokener_error_desc().  So a simple edit needs to be made to
 change:
 json_tokener_errors[jstok->error]
 to:
 json_tokener_error_desc(jstok->error)
 Making this simple change from the deprecated array to the new function
 allows compilation to proceed to completion.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2539#comment:3>
