[postgis-tickets] [PostGIS] #2387: Include pagc_address_parser as part of PostGIS (was: Register pagc_address_standardizer as a PostgreSQL extension package)
PostGIS trac at osgeo.org
Fri May 16 07:26:09 PDT 2014
 Reporter:  robe                 |       Owner:  robe
     Type:  enhancement          |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.2.0
Component:  pagc_address_parser  |     Version:  trunk
 Keywords:                       |
Description changed by robe:
Old description:
> I was also thinking since we are at a stable essentially 1.0 point and
> the address_standardizer is now wrapped as an extension and its fairly
> light-weight (only extra dependencies on pcre stuff available on most
> Linux/Unix distros), it might be worthwhile to register it as an official
> PostgreSQL extension at
> http://manager.pgxn.org/
> Thinking about it more, since it doesn't have any direct reliance on
> PostGIS, it will probably be better served if its stands on its own since
> it has value without anything else.
> The other benefit is that folks on Unix/Linux can then install it using
> the pgxn client.
> http://pgxnclient.projects.pgfoundry.org/
> Then I can amend the instructions accordingly to offer this simplified
> instruction set in PostGIS docs in additiona to hte standard svn checkout
> approach.
> Sadly this approach doesn't work on Windows cause windows doesn't really
> support PostgreSQL make files unless you are building under Mingw. (strk
> keep your mouth shut. :) )
> I'll be shipping address_standardizer with the newly dubbed (PostGIS
> bundle starting at 2.1) and update our instructions accordingly   so
> doesn't matter for windows users.
New description:
 Thought about this more and since the large majority of users are PostGIS
 users, makes sense to just package it with PostGIS.  That will minimize on
 all the questions about where to file bugs and since tiger uses it might
 allow for easier build, so people don't have to compile it on their own.
 Discussed this with Steve Woodbridge and he's for the idea.  That would
 mean we'll need to give him postgis repo access.
 ----- OLD THOUGHT --
 I was also thinking since we are at a stable essentially 1.0 point and the
 address_standardizer is now wrapped as an extension and its fairly light-
 weight (only extra dependencies on pcre stuff available on most Linux/Unix
 distros), it might be worthwhile to register it as an official PostgreSQL
 extension at
 the pgxn client.
 approach.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2387#comment:1>
