[postgis-tickets] [PostGIS] #2739: ST_Intersection problem
PostGIS trac at osgeo.org
Fri May 16 13:24:05 PDT 2014
 Reporter:  pascal   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.4
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
Changes (by robe):
  * milestone:  => PostGIS 2.1.4
Comment:
 Your table geometries got cut off and they are ST_AsText representations
 so don't have the full resolution of the original  geometries.  Can you
 provide an sql dump file that contains the two tables in question each
 containing the geometry in question?
 Also please provide your version details:
 SELECT version(), postgis_full_version();
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2739#comment:1>
