[postgis-tickets] [PostGIS] #2608: Streamline stackbuilder by getting rid of login credentials
PostGIS trac at osgeo.org
Sun May 18 07:56:06 PDT 2014
  Reporter:  robe                   |       Owner:  robe
      Type:  enhancement            |      Status:  closed
  Priority:  medium                 |   Milestone:  PostGIS 2.1.3
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:  fixed                  |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I decided to keep the create spatial database option.  Seems people
 actually find that useful especially if you are creating a silent
 installer (which I gotta fix).
 However, I did change in 2.1.3 release so that if the create spatial
 database option is not checked, then the username/password dialog screen
 will not come up.  By default it isn't checked.  It will come up if create
 spatial database option is checked.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2608#comment:2>
