[postgis-tickets] [PostGIS] #2741: stackbuilder 2.0/2.1 option for setting new PostGIS GDAL Raster variables
PostGIS trac at osgeo.org
Sun May 18 08:04:23 PDT 2014
 Reporter:  robe                   |       Owner:  strk
     Type:  enhancement            |      Status:  new
 Priority:  medium                 |   Milestone:
Component:  build/upgrade/install  |     Version:  2.0.x
 Keywords:                         |
 This is more of a note -- in 2.0.6 and 2.1.3 I added extra dialogs to
 windows installer to set the environment variables:
 It's not that elegant - If you say yes to the two new prompts it sets the
 system variables:
 POSTGIS_GDAL_ENABLED_DRIVERS=GTiff PNG JPEG GIF XYZ DTED USGSDEM AAIGrid
 and
 POSTGIS_ENABLE_OUTDB_RASTERS=1
 If you say no it doesn nothing.
 Ideally I probably should have allowed them to override the drivers but I
 figure I'm going to take this out when 2.2 comes around anyway and have
 them use GUCs though I may set the GUCs for sample database in which case
 I'd only ask for the prompts if they choose that option.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2741>
