[postgis-tickets] [PostGIS] #828: [raster] Loader generates wrong SQL when NODATA for a band is NaN
PostGIS trac at osgeo.org
Mon May 19 00:22:19 PDT 2014
  Reporter:  jorgearevalo  |       Owner:  jorgearevalo
      Type:  defect        |      Status:  reopened
  Priority:  medium        |   Milestone:  PostGIS 2.1.4
 Component:  raster        |     Version:  trunk
Resolution:                |    Keywords:  loader,nan,gdal
Changes (by sbl):
 * cc: sbl (added)
  * status:  closed => reopened
  * resolution:  fixed =>
  * milestone:  PostGIS 2.0.0 => PostGIS 2.1.4
Comment:
 Reopening,since the problem seems to reoccure (http://osgeo-
 org.1560.x6.nabble.com/GRASS-created-geotiff-do-not-properly-load-into-
 PostGIS-raster2pgsql-tt5140697.html).
 Looks like the NaN check in the Python version did not make it to the
 C-version... Maybe raster2pgsql needs to call CPLIsNan from GDAL
 explicitly:
 See: http://osgeo-org.1560.x6.nabble.com/gdal-dev-
 GDALSetRasterNoDataValue-and-NaN-td4996633.html
Ticket URL: <http://trac.osgeo.org/postgis/ticket/828#comment:3>
