[postgis-tickets] [PostGIS] #2746: winnie 9.4 PostGIS 2.2. build doesn't load in EDB 9.4 beta 32-bit
PostGIS trac at osgeo.org
Wed May 21 13:14:15 PDT 2014
 Reporter:  robe                   |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 Yap I think something changed in how they are handling Interlocking.
 Just to simplify things a bit, I tried building pg_trgm extension and
 while my mingw32 can use the extensions provided by the PostgreSQL
 9.4beta1 build EDB windows 32 build the pg_trgm I built (under
 mingw64-w32) and tried to sneak in to my PostgreSQL 9.4 vc build complains
 about the same non-existent function.
 I'm suspecting something different changed in 9.4 in the
 http://doxygen.postgresql.org/s__lock_8h_source.html
 src\include\storage\s_lock.h
 since that is where I see reference to _InterlockedExchange and lots of
 conditions depending on 32-bit/64-bit/intel etc.
 As much as I hate to say so. We may need to revisit cmake sooner than
 later otherwise I may not be able to build for 9.4 windows 32-bit.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2746#comment:3>
