[postgis-tickets] [PostGIS] #2746: winnie 9.4 PostGIS 2.2.or 2.1 build doesn't load in EDB 9.4 beta 32-bit (was: winnie 9.4 PostGIS 2.2. build doesn't load in EDB 9.4 beta 32-bit)
PostGIS trac at osgeo.org
Sat May 24 11:06:07 PDT 2014
 Reporter:  robe                   |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.1.4
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Changes (by robe):
  * milestone:  PostGIS 2.2.0 => PostGIS 2.1.4
Comment:
 switching this to 2.1.  Since we aren't going to make the 9.4 cut, this
 has to be fixed for 2.1 as well.  though I think the issue is with
 PostgreSQL 9.4, so probably nothing needs to change in our code base.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2746#comment:8>
