[postgis-tickets] [PostGIS] #2746: winnie 9.4 PostGIS 2.2.or 2.1 build doesn't load in EDB 9.4 beta 32-bit
PostGIS trac at osgeo.org
Sun May 25 21:12:01 PDT 2014
  Reporter:  robe                   |       Owner:  robe
      Type:  defect                 |      Status:  closed
  Priority:  blocker                |   Milestone:  PostGIS 2.1.4
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:  fixed                  |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Looking good so far. All tests pass against my EDB 32-bit 9.4beta 1 --
 ain't that a beaut site:
 PostgreSQL 9.4beta1, compiled by Visual C++ build 1800, 32-bit
   Postgis 2.2.0dev
  - r12585
  - 2014-05-26 03:53:17
   scripts 2.2.0dev r12585
   raster scripts 2.2.0dev r12585
   GEOS: 3.5.0dev-CAPI-1.9.0 r3985
   PROJ: Rel. 4.8.0, 6 March 2012
   GDAL: GDAL 1.11.0, released 2014/04/16
 Postgres devs are still deciding what do to about this:
 http://www.postgresql.org/message-id/12441.1401043380@sss.pgh.pa.us
 I'm uncomfortable about the fact that my gcc 4.8.0 compiled but had that
 extra load function reference making it inoperable, and replacing that
 win32 template file seemed to not fix the issue or perhaps it did and I
 missed something.
 I'm even more puzzled that upgrading to gcc 4.8.1 made configure not work
 at all but changing the template/win32 file back to
 LDFLAGS="-Wl,--allow-multiple-definition"
 fixed both problems.  I'll look the gift horse in the mouth later.
 So far I've built 2.2 (and whole new set of libraries GDAL 1.11.0, GEOS
 3.5.0dev, etc. with my new chain).  For some reason couldn't build libxml2
 so using my gcc 4.8.0 built one for compiling. I never distribute the
 mingw libxml anyway.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2746#comment:11>
