[postgis-tickets] [PostGIS] #2748: Deprecate all functions with underscore_names rather than CamelCase
PostGIS trac at osgeo.org
Mon May 26 01:31:46 PDT 2014
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
 Spin-off of #1994, for those still not deprecated.
     ST_Shift_Longitude(geometry)
     ST_Combine_BBox(box2d,geometry)
     ST_find_extent(text,text,text) RETURNS box2d AS
     ST_find_extent(text,text) RETURNS box2d AS
     ST_mem_size(geometry)
     ST_3DLength_spheroid(geometry, spheroid)
     ST_length_spheroid(geometry, spheroid)
     ST_length2d_spheroid(geometry, spheroid)
     ST_distance_spheroid(geom1 geometry, geom2 geometry,spheroid)
     ST_point_inside_circle(geometry,float8,float8,float8)
     ST_locate_between_measures(geometry, float8, float8)
     ST_locate_along_measure(geometry, float8)
     ST_Combine_BBox(box3d,geometry)
     ST_distance_sphere(geom1 geometry, geom2 geometry)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2748>
